4WS steering problems - p/s pump over pressured?
Postby darkwolf » Mon Dec 24, 2007 12:05 am
ST183 Celica 4WS.
The 4WS light is on, and when I looked at the power steering fluid reservoir the fluid was flowing around inside like it is under pressure.
Now my thoughts on this have been that the lines running to the 4WS controller at the rear are blocked. This could be causing a stoppage of fluid going to the back thus all pressure being pushed through the front half of the system, this extra pressure would be causing the stirring in the reservoir that I am seeing. Now it does this from fresh cold key start to long running to long run restart. Am I possibly correct in my diagnosis? If so, how would I find exactly where the blockage is and how do I remove it. Obviously I don't want the blockage moving to a controlling cylinder or anything and seizing that.
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
Postby Mr Revhead » Mon Dec 24, 2007 8:36 am
that is normal
the fluid gets pumped around the systewm, thats how it works
and the rear steering is self contained in the bacl, it does not use fluid from the front. its electric.
Postby darkwolf » Mon Dec 24, 2007 10:36 am
Bugger :(
Back to the drawing board thanks for your help
darkwolf
Postby Mr Revhead » Mon Dec 24, 2007 10:40 am
iirc in the thread in general about getting rid of a car, someone posted a link about how to diagnose that system?
Postby Mr Revhead » Mon Dec 24, 2007 10:48 am
Postby Mr Revhead » Mon Dec 24, 2007 10:54 am
