Hi, I have lately a weird cooling problem. When I drive 50 in the 4th gear, the engine suddenly gets hot. I can feel it coming by the air of the heater. suddenly cold air is comming from the heater, and about 10 seconds later the engine starts to get hot. Then I switch of the engine and start again, I can see the temp immediately cooling down to normal.
I have replaced the thermostat without luck. Still got the problem...
Is it possible that the rotorblade of the waterpump is sometimes loose? Is it a lot of work to replace the pump?
The system is not leaking coolant
