79rolla wrote:
has anyone actuly tryed that on here??
the key wen first running in is not to leave at same rpm for verry long... and then normaily dont drive relly hard...
main point.. dont let idol at same rpm and dont hold it in gears for too long
IH8TEC wrote:i can see why you want to get it going right away, but damn, why not wait until its all done then do it? you've waited how long. and it's good to get the turbo working on there as well to give that a bit of run in. (assuming it's brand new, cause you have to build up oil pressure in all those lines, and turbo before you start it with all that too
IH8TEC wrote:boost is good (not much) to help bed in the rings. we did same with bazdas motor once we put the motor back in with the JE's and new rings. only difference is he had a map already, which i dont beleive you have.
i would suggest talking to the tuner (andre?) getting him to start it, run it for a bit on the dyno knowing it's fresh motor, so he can give it some safe timing and adjust the fuel a bit so you can drive it for a thousand kms or whatever, then go back and do full tune. OR, run it in on the dyno (costs bit more)
