4agze s/c oil feed for turbo
Postby l1ttle_d3vil » Fri Jan 04, 2008 8:35 pm
can the oil feed sandwich plate thing for the supercharger off an aw11 4agze be used as an oil feed for a 4agte? or will it be too big...? T2 series turbo...
never heard anyone say to use it, everyone seems to get oil feeds from elsewhere so i'm wondering if theres a reason not to use it?
-matt
Postby Crucible » Fri Jan 04, 2008 9:08 pm
you could always just run it from oil press switch taping?
not familiar with you're setup but sandwich plates can take up a bit of room on a fwd Turbo.
Crucible
Real Life Mechanic
Postby ChaosAD » Fri Jan 04, 2008 10:04 pm
The s/c has its own oil.
The sandwich plate is probably for the oil cooler built into the radiator.
Most people tap into the oil press switch I think.
ChaosAD
Postby l1ttle_d3vil » Fri Jan 04, 2008 10:12 pm
this is the thingee i'm talking about... 10mm line coming off it at the moment but I could probably get anything made up if thats too big.
will just set it up off the pressure switch if this isn't suitable.
Postby Pelo » Fri Jan 04, 2008 10:35 pm
thats for your oil cooler. you may not have room with a turbo but it should work.
Pelo
Postby Crucible » Fri Jan 04, 2008 10:36 pm
IMO,
get rid of it, run the filter against the block.
if you wanna run a cooler use a sandwich plate but mount the filter and cooler remotely.
It'll give you more room to work the manifold etc, upto you though :)
Crucible
Real Life Mechanic
Postby evil_si » Sat Jan 05, 2008 9:18 am
as said thats just the oil cooler. only the early 4ages and zes seem to have it.
easier to get rid of it all together,
run the turbo oil feed from the oil pressure sensor drilling in the block,
put in a T piece run the sensor off the side and the turbo feed straight off the end of it
use stainless or steel fittings over brass and keep them as short as possible
evil_si
Postby themaleman » Sun Jan 06, 2008 12:01 pm
[img][img]http://img235.imageshack.us/img235/2397/image654nl5.th.jpg[/img]
t piece from oil pres sensor i think[/img]
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby sergei » Sun Jan 06, 2008 12:18 pm
that oil cooler line is working from pressure control valve - the oil only goes through that line when oil pressure is above certain level. Very bad idea to feed turbo trough it.
And return into sump is way too small.
Postby l1ttle_d3vil » Sun Jan 06, 2008 1:24 pm
thanks sergei, thats what I was wondering - it clears my manifold fine but there may have been another reason not to use it.
don't worry about the return line, thats still the factory ze return line in there! definitely not using that one for the turbo. getting it all setup next weekend
:lol: :lol: :lol:
Postby tsoob » Sun Jan 06, 2008 1:59 pm
just done mine, i really wish i had done a remote mounted oil filter as now i will have to pull the manifold off again to do it.
tsoob
Postby matt dunn » Thu Jan 10, 2008 2:47 am
sergei wrote:that oil cooler line is working from pressure control valve - the oil only goes through that line when oil pressure is above certain level. Very bad idea to feed turbo trough it.
I agree, no way should that be used for a turbo oil feed,
as it wont get oil all the time.
Postby Paulio » Thu Jan 10, 2008 7:58 am
themaleman wrote:[img][img]http://img235.imageshack.us/img235/2397/image654nl5.th.jpg[/img]
this is what I have done also
Paulio
