silvertop cam angle sensor
Postby petrolhead » Fri Jan 04, 2008 10:02 pm
hi guys i am putting a silvertop into my ke25 and was wondering wether i can do away with my dizzy/ cam angle sensor completely in favour of a crank angle sensor im runnig a link computer with wasted spark setup from an evo. if so any ideas on what to het sensor from any help woul be appreciated.
petrolhead
Postby Lloyd » Sat Jan 05, 2008 11:09 am
Pull the cap and rotor etc off and its the same sensor setup as the GZE CAS on the front of the head. No reason why you cant use it for Link. Should have 2 sensors in the dizzy, a 24 tooth (I think) rpm pickup and a 2 tooth TDC one.
Postby matt dunn » Thu Jan 10, 2008 2:30 am
Yeah that is what I have done.
Run it with no cap or rotor and evo type coils.
I made a cover for mine out of an old dist cap though.
