tial 35mm wastegates?
Postby l1ttle_d3vil » Wed Jan 09, 2008 10:02 pm
do these exist? they don't seem to be mentioned on the tial website but may just be a discontinued line or something - they are on ebay /overseas sites though.
do they use the same springs as a 38mm wastegate? and is there going to be a massive different of performance between a 35mm and 38mm?
Postby QikStarlie » Wed Jan 09, 2008 10:33 pm
discontinued far as i know and were replaced by the the 38mm gates.
use to have one on my car, was stupidly loud. pretty sure the springs are the same as the 38mm ones
QikStarlie
Postby ChaosAD » Thu Jan 10, 2008 12:51 am
smaller gates would give better boost control, until you start boost creeping etc.
But if porting the standard gate doesnt work, a 38 would prolly be the way to go anyways.
ChaosAD
Postby l1ttle_d3vil » Thu Jan 10, 2008 8:13 am
what decides the size of the gate required? boost, or the size of the turbo too? i'm running a t28 and anything up to 20psi...
sounds like the 35mm ones are old anyway so would be better to go with a 38mm for that reason...just theres one on TM at the moment :lol:
Postby tsoob » Thu Jan 10, 2008 10:03 am
im running a 38mm on my t28 and its great, i just need to work with the spring now as it opens up on 9psi. i want to run 18psi
tsoob
