boss kit
boss kit
Postby Sonic » Thu Jan 10, 2008 9:24 am
would an ae101 boss kit fit an ae92??
Sonic
Postby postfach » Thu Jan 10, 2008 9:26 am
i think most (if not all?) toyota ones are the same
postfach
Postby solitaire » Thu Jan 10, 2008 11:45 pm
id be carefull... there are 4 different kits for sw20's from hkb...
COULD be the same for the ae's... best to check first or make sure you can return it :wink:
AE92, KZJ120, KDJ120
solitaire
Postby slighty_sykotic » Fri Jan 11, 2008 12:05 am
Will fit, but you might have to make holes in the back for the indicators. Thats normally the difference between alot of models.
slighty_sykotic
Postby pc » Fri Jan 11, 2008 10:44 am
All the ones I have tried fit, but some are too short and there is about 5mm between the indicator stalks and the steering wheel.
So getting the right height kit is important.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
