****4agze turbo problem air in sump****
Postby corolla gt » Sun Jan 13, 2008 1:16 pm
my 4agze turbo engine is pmpressing air into the sump so wen i turn it off u can hear a hissing sound then u opull the dip stick out and it lets all the pressure out ov the sump
im shore this is not gud at all the motor is sopost 2 b rebuilt by baz on toyspeed and i brought off here like 1year ago have just got it started can anyone tell me this problem?
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby no_8wire » Sun Jan 13, 2008 1:24 pm
Is the oil blowback line(from top of cam cover) going to a oil catch can or to the manifold? If its in the stock position (to the manifold) try putting in a oil catchcan.
no_8wire
Postby Bumpy » Sun Jan 13, 2008 2:22 pm
Check the breathers on your rocker cover, and make sure your pcv valve is opening up properly.
Sounds wierd that it's coming from your dip stick.
Bumpy
Postby IH8TEC » Sun Jan 13, 2008 9:23 pm
4agte's ABSOLUTELY LOVE TO BREATH, if you have just the std one breather, ditch it. i've upgraded my entire breathing system, cause i needed more
(i have a pair of red cam covers that were on my old engine that are for sale, can also provide -8 lines with the fittings and a small simota catch can :lol: )
Postby l1ttle_d3vil » Mon Jan 14, 2008 8:06 am
IH8TEC wrote:4agte's ABSOLUTELY LOVE TO BREATH, if you have just the std one breather, ditch it. i've upgraded my entire breathing system, cause i needed more
would having the original breather system cause oil / vapours to come out when the BOV vents? or is that likely to be a problem on the turbo side? just noticed a fine mist coming out every so often...
Postby IH8TEC » Mon Jan 14, 2008 11:58 am
could possibly, as the vapours from catch can go back to before the throttle body. and when that shuts, go out the bov. but at same time could possibly be the front seal on turbo
Postby corolla gt » Mon Jan 14, 2008 4:57 pm
i do have a oil catch can allready and have sealed up the inlet valve piece and just have 1 goin frm the stanard 4age cam cover to a oil catch should i put 4agze cam cover on my 4age 1 pvc mite not owrk..
i got told if u have the inlet 1 goin into oil catch can wen turbo the boost gets forced into the catch can and can make it leak?
im just really hoping it isnt my piston rings because the motor is rebuilt
i took it to a shop to get tuned and got it back saying i have a masive inlet leak and turbo blowin and water leak so i was wondering if it was because ov a blowing turbo and inlet leak on a brand new motor if that would be why?
please if you guys could help because 4age turbos are new to me well turbos are lol
corolla gt
Postby Crampy » Tue Jan 15, 2008 4:35 pm
Sounds like your turbo is toast and you need to make sure you've bolted up the inlet manifold and throttle body properly.
Crampy
Postby AE86fan » Tue Jan 15, 2008 9:10 pm
Might pay to check your cam timing....if its a new engine cam timing might be a bit off and that can cause excessive breathing.
1984 NZ AE86
AE86fan
