help please : brakes
Postby LEV_101 » Sun Jan 13, 2008 7:50 pm
hey guys,
was fitting some trd rotors on the altezza and one of the rotors was really stuck :S the other one was sweet and easy to take off. so i had to use force and hammer etc to remove the disc ( its for the rear so thats why it was stuck )
after about 30 mins of hard work i got it off and now the drum brake pad is very loose and the spring holding it is now hitting the stud when the it rotates.
did i bend or have broken the pin/clip thingy ?
thanks
LEV_101
Postby postfach » Sun Jan 13, 2008 8:08 pm
is the little cap that holds the spring in place still on properly? looks like its just come undone or something. maybe you just dislodged something?
postfach
Postby Lloyd » Sun Jan 13, 2008 8:52 pm
Push the shoe back in so you can get the clip, spring and cap out and see if any damage has been done. Probably just pulled it right through. Get it out and have a look first
Postby LEV_101 » Sun Jan 13, 2008 10:01 pm
HRT wrote:Push the shoe back in so you can get the clip, spring and cap out and see if any damage has been done. Probably just pulled it right through. Get it out and have a look first
how would i know if the pin needs replacing ?
LEV_101
Postby gmacrae » Mon Jan 14, 2008 12:50 pm
so you tried to remove the rotor with the handbrake on? If so, and you bashed it off, you could've damaged the shoe's or whatever holds them in place
gmacrae
Re: help please : brakes
Postby fivebob » Mon Jan 14, 2008 1:05 pm
LEV_101 wrote:was fitting some trd rotors on the altezza and one of the rotors was really stuck :S the other one was sweet and easy to take off. so i had to use force and hammer etc to remove the disc ( its for the rear so thats why it was stuck )
So you didn't slacken off the drum brake adjusters before trying to remove the rotor/drum and then you beat the crap out of it :roll:
If there's on thing I've learned over the years it's that if you have to use brute force and ignorance to remove/ fit a part then you're probably doing it wrong. So at that point it's best to take a close look and see why it's not coming apart easily :wink:
Doesn't look like you've broken anything too badly, and even if the pin is slightly bent then it should be ok if you straighten it out.
Just remember to back off the adjusters before you fit the new rotors/drums and the adjust them up after you've installed them. There should be a hole in the rotor that allows you to reach the adjuster wheel.
