4age leaking water
4age leaking water
Postby fx gt » Thu Jan 17, 2008 8:53 pm
the water pump seized on my 4age.redtop fxgt
so i replaced it and new gasket plus the gasket glue. but when i fill the radaitor back up it starts dripping water from somewhere( car not turned on)
it isnt pissing out but still enough not to drive it :P
checked all bolts for water pump and there all there!
has anyone had this issue before?
there is one bolt i no of i did not replace becasuse its so hard to get in and so close to cambelt i think it never was there!
anyhelp would be great
fx gt
Postby Bling » Thu Jan 17, 2008 9:00 pm
find out exactly where its leaking from by drying it all off and waiting for a drip to form, maybe it needs that bolt, maybe it needs more gasket glue / sealant.
Postby l1ttle_d3vil » Thu Jan 17, 2008 9:47 pm
my engine had about 6 leaks when I first put it in, pissed water out everywhere without the engine even running. got it started anyway (to make sure it ran), let it warm up while keeping an eye on the water.
its never leaked since. when it all warms up it sorta seals everything together. might work in your case... but would pay to still keep an eye on the temp and water level!
Postby Crucible » Thu Jan 17, 2008 10:35 pm
half the bolts secure the pump to the housing the other half bolt the housing to the block (through the pump).
did you replace the oring between the block and housing?, if not theres a good chance youve broken the seal, youll find the oring will be hard and brittle.
Crucible
Real Life Mechanic
Postby Trls250s » Fri Jan 18, 2008 9:18 am
If its leaking onto the front of your engine it will be your waterpump.
Tighten all the bolts and use the correct lengths for the holes it requires.
The gasket and the mechanical seal (the one on the pully) need to be heated up before they actually work.
This happened to mine. Keep the water level up and run the engine temperature up to operating. Then hop in and take it for a cane, and i mean a good cane. Not to far maybe 5 - 10km, but give it shit.
Double check everything is alright and hopefully it should have stopped leaking water.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby pc » Fri Jan 18, 2008 9:38 am
There are 2 halfs to a water pump and if you buy from repco etc. you just get the pump half and no o-rings.
Then when you unbolt the half, the rubber o-rings which will be old/hard/brittle will no longer be making a seal. it's best to pull both parts of the block, bolt/goo them together on the bench, then replace the o-rings and bolt it back on.
taking it for a thrash is not a good idea, if it's leaking, then it's leaking.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby fx gt » Fri Jan 18, 2008 5:58 pm
True-No-Turbo wrote:half the bolts secure the pump to the housing the other half bolt the housing to the block (through the pump).
nah didnt no about the o ring. will have to do it.
fx gt
Postby fx gt » Fri Jan 18, 2008 6:01 pm
Trls250s wrote:If its leaking onto the front of your engine it will be your waterpump.
This happened to mine. Keep the water level up and run the engine temperature up to operating. Then hop in and take it for a cane, and i mean a good cane. Not to far maybe 5 - 10km, but give it sh*t.
what the $&#$%
for one im not going to listen to you about taking it for a cane.
that sounds like a dam stupid idea. if i was A noob i would have done so and probly blown my engine, all because of your stupid post! its not going to solve anythink
fx gt
Postby fx gt » Fri Jan 18, 2008 6:03 pm
pc wrote:There are 2 halfs to a water pump and if you buy from repco etc. you just get the pump half and no o-rings.
yeah got it from repco. thats stupid!
so the other half will just come of if i take the bolts around pump of?
also if i slap it togher will it still fit in engine bay with the engine still in?thinking there might not be enough clerance
fx gt
Postby Crucible » Fri Jan 18, 2008 7:45 pm
Its tight but you'll get it in as a unit. Use a screwdriver and dig the old oring out, get it all clean, then silicone the new oring in place.
just try and bolt the pump assembly on straight without moving side to side as not to shift the oring. I normally pressure test the cooling system to make sure theres no leaks before going any further, but thats just a precaution, youll be right mate!
Crucible
Real Life Mechanic
Postby Trls250s » Fri Jan 18, 2008 9:19 pm
Haha my words have much wisdom...
Its a dirty 4age and its not gonna hurt it.
I redid my seals on my water pump 4 times and it still continued to leak, a friend of mine just said "leave it, take it for a little drive and you'll be suprised that at how much it reduces it" suprise suprise it worked.
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
