4agte throttle-body upgrades?
Postby NOLAW » Sun Jan 20, 2008 1:45 pm
is it worth upgrading the throttle body on a 4agte, and are there any throttle bodies other than the standard 4age one that can bolt to 4age smallport inlet manifold? (pics of manifold down the page)
as im not looking into getting a custom manifold at the moment just to fit a different throttle body to.
NOLAW
Postby bluemaumau » Sun Jan 20, 2008 2:47 pm
are you running a 4agze manifold on a 4agte? :?
Postby NOLAW » Sun Jan 20, 2008 3:40 pm
im not actualy sure what 4age it is off but its not 4agze, il let you guys confirm what manifold it is, it is a FWD mani that has been modified to suit RWD, surfaces have been grinded back.
the block and head is an AE101 4agze smallport so id say the manifold is smallport aswel if this is anyhelp
this is my manifold, cut and shut to suit RWD
this is what it looked like before i grinded back (sample pic only)
NOLAW
Postby IH8TEC » Sun Jan 20, 2008 4:01 pm
to be honest, there probably isn't much of a gain unless you are running serious power. the 4age one i have is like 58mm, if you go bigger you may as well upgrade the intake to 3inch from the intercooler to t/b to help make use of it.
4age one ftw in my opinion :D
Postby Crampy » Sun Jan 20, 2008 4:04 pm
Yep, that's a smallport manifold.
There's nothing wrong with the stock 4AGE throttle body. Brendon (ih8tec), among others, makes about 200kw at the wheels on a stock 4AGE throttle.
Crampy
Users browsing this forum: Bing [Bot] and 29 guests
