how does rad fan coolant temp sensor work?
Postby gmacrae » Fri Jan 25, 2008 11:29 am
Howzit... i want to get the radiator fan running in my fxgt using the fan temp sensor thats in the silvertop
Currently the sensor isnt wired up to anything, i've just got the relay tripped to run the fan non stop. Does this sensor ground out at a certain temp to trip the fan relay or does the stock ecu monitor it to fire the fan relay? Just wanna know how i should be wiring it to use this sensor to make the fan run only when it needs to.
Gene
gmacrae
Postby barryogen » Fri Jan 25, 2008 2:39 pm
along these lines, other than taking a bit longer to get up to operating temp, a bit more drain on however it is run(meaning electrically or crank?), and a bit more wear on it...
is there a downside to having it running all the time?
barryogen
2ZZ Guru in training
Postby gepsk8 » Fri Jan 25, 2008 6:27 pm
the sensor earths til it reachs temp to turn relay of, get relay is on when keys on turns off when relay reachs temp, if u get that.
O272754663
gepsk8
Postby Bumpy » Fri Jan 25, 2008 10:36 pm
gepsk8 wrote:the sensor earths til it reachs temp to turn relay of, get relay is on when keys on turns off when relay reachs temp, if u get that.
I would say it's the other way round. The sensor earths when engine gets to temp, otherwise if the plug was out of the sensor, fan would go all the time ...
Bumpy
Postby rollaholic » Fri Jan 25, 2008 10:37 pm
it does go all the time when its unplugged.
good way to check if your fan is dead!
Postby matt dunn » Fri Jan 25, 2008 11:24 pm
Correct, the single wire toyota fan switches work the opposire to what you think,
they earth out below the set temp to stop the fans,
which is why unplugged they go all th time,
and the same feed goes through the AC pressure sw,
so if that is unplugged they go also.
Postby Bumpy » Sat Jan 26, 2008 7:44 am
When I did my clutch on my Glanza, that single fan wire was something I missed, car nearly over heated cause it wasnt plugged in and fan wasnt going at all .... Could it have been something else?
Bumpy
Postby gepsk8 » Sat Jan 26, 2008 12:53 pm
what years ur car? as more late models car are now ecu controled.
O272754663
gepsk8
Postby Bumpy » Sun Jan 27, 2008 10:06 am
Oh ok, yea it's a '96 Glanza
Bumpy
Postby gmacrae » Tue Jan 29, 2008 10:19 am
good'o thanks guys :)
gmacrae
