removing suspension bushes, your techniques??
Postby Mike- » Sat Jan 26, 2008 7:18 pm
i had a search but found nothing,
i need to replace the control arm bushes on my ae92 for a warrant, ive got a set of nolathane bushes ready to go in but how do you get the old ones out,
ive been bashing one with a rubber mallet but it hasnt budged,
whats the best way to do it?
Mike-
Postby rollaholic » Sat Jan 26, 2008 7:20 pm
20 ton press usually does the trick for me.
Postby Mike- » Sat Jan 26, 2008 7:23 pm
lol so im pretty much screwed??
Mike-
Postby rollaholic » Sat Jan 26, 2008 7:27 pm
probably, you need to push the bush out from around the outside, on the steel edges - hitting the rubber inner with a mallet is never going to budge it.
your local garage should be able to help you, or ADL in mt roskill are good if you are in that area.
Postby Dell'Orto » Sat Jan 26, 2008 7:34 pm
Drill holes around the centre crush tube until you can remove it, then carefully with a hacksaw cut into the metal housing a couple of times, it comes out.
Hugely easier with a press, but if you've not got access to one, that method works well. Not as messy as burning the bush out either.
Postby GDII » Sat Jan 26, 2008 7:46 pm
I drilled mine out, but these were in my rear trailing arms.
Some were so stuffed I just hit the centre with a hammer they fell out.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Ae92typeX » Sat Jan 26, 2008 9:22 pm
Dell'Orto wrote:Drill holes around the centre crush tube until you can remove it, then carefully with a hacksaw cut into the metal housing a couple of times, it comes out.
done similar many times.
Depending how handy you are, could fab up a custom press with a cheap$15 bottlejack also.
Ae92typeX
Postby Crucible » Sun Jan 27, 2008 12:49 am
rear trailing arm bushes? just whack them out with a ballpein..u dont need a press, the bushes from repco are two piece nolathane with centre bush...takes like 5 mins.
one piece Front lower arm bushes come out easy if you melt the rubber with a gas axe then hit em out with a socket, drift. just keep the heat away from the arm itself. You can press in most fr lower arm bushes with a vice and big socket, they can be quite hard to support in a press.
Crucible
Real Life Mechanic
Postby gasman » Sun Jan 27, 2008 8:22 am
i just use one of those pullers. if that doesnt work then fab up a suitable puller from a through bolt that goes through a large socket and the bush then on the other end a large washer and a nut. then just wind it up and the bush will pop into the socket
"What can possibly go wrong?"
gasman
Postby thegreatestben » Sun Jan 27, 2008 10:30 am
I used a bit of pipe and assorted sized bolts and pieces of metal in a bench vice. but a press would make it a lot more of a pleasant job.
thegreatestben
