by strx7 » Mon Jan 28, 2008 9:56 pm
the low down on rx7 injectors
The ones with the offset locator lug as per your pic, are LATE series 4 13BT, very late 1987 and early 1988. they are high impendance. the part number on them in 195500-1370. 195500-1370 fitted to 1985 thru 1987 Series 4 13BT have the locator lug in the centre, these are low impendence, and share the plug with lots of early nippon denso injectors, commonly found on injected mazda & toyota thru the 80's.
the ones you mention with the 'common' rounder plug are series 5 high impendence injectors, that style of plug is 'common' on modern vehicles.
all of the ones mentioned above are 550cc
you can also get Series 6-8 13BREW injectors, they are side feed, 550cc primary and 850cc secondary
Motorsport Bay of Plenty -
http://www.mbop.org.nz
