Caldina Gtt turbo
Caldina Gtt turbo
Postby Caldina3SGTE » Tue Jan 29, 2008 4:21 pm
i'm new at this turbo thing and just wanted to know if a ct20b exhaust housing will fit on a caldina gtt turbo??
thanks
Caldina3SGTE
Postby postfach » Tue Jan 29, 2008 4:27 pm
pretty sure you'll find that the exhaust housing on the caldinas turbo is actually part of the exhaust manifold, and can't be changed.
postfach
Postby sergei » Tue Jan 29, 2008 4:52 pm
As far as I've seen "CT20b" is very different to GTT turbo, so I highly doubt that it will "fit". (you can make it fit, by machining, but I don't know how twin entry part will work with single entry turbine wheel). As far as I know ST205 manifold can be used to adapt ST205 turbo (with down pipe).
