bluemaumau wrote:also interested in this, shouldnt it be higher on the sump, so it actually drains?
Trls250s wrote:I wouldnt have thought it would matter where on the sump the oil was mounted anyways as the oil pressure (or vacuum) from the pump circulating the oil would 'suck' the oil out of the turbo anyways.
You only need to leave your oil pressure sensor out of your block to see how much oil comes out at idle, so i would imagine at around 2 - 3k rpm there would be a lot of oil flowing around.
l1ttle_d3vil wrote:it has to be able to drain out of the hose as freely as possible, if it can't it will cause all sorts of problems. its only gravity drained so the slightest thing can block it.
this is my setup - its about as close to the top of the sump as I could get.
l1ttle_d3vil wrote:thats in a top mount setup. come around next time you're up here if you wana gawk. that was done with the sump still fitted too so could be done better off the engine
l1ttle_d3vil wrote:oh well, rings and headgaskset are gone on the engine anywaystill boosts hard though (on a bluetop ecu). will be coming out soon for a ze + link.
