Hi there guys,
From what I have read, a stock tyre normaly has a rectangular contact patch, longer from the front to back(of the tyre).
If you put a wider tire on than stock, the size of the contact patch remains practically the same, but you widen and shorten the contact patch making it more square, or to the extreme, a wide flat rectangle.
Firstly, I realise that there are more to tyres than just the contact patches, but I'm trying to learn one thing at a time... So, can anyone explain what the charactoristics of a stock tyre contact patch vs the other two examples I have given above?
From my own thinking(which may well be wrong), the stock should give a more predictable and forgiving when moving into a brake enforced skid(meaning to slam on the brakes), where as the other two would be more forgiving on lateral movements.
although, from all accounts in pretty much all motorsport they put big fat tyres on everything and it appears to "make it better".
I'd rather not see guesses in this thread, so ideally only facts, but hey, once the thread is out there, it's not like I can stop anyone.
