how do i remove the speed cut on my st205 (190kph)
I don't want to buy a new ecu at the moment.
is there some kind f small plug in thing i can get that will just remove the speed cut?
Mr.Phreak wrote:HKS SLD or if you wanted to get a bit flashy, something like the Apexi RSM
classique71 wrote:or own a group A
.:O4AGTZ:. wrote:i use an apexi rsm on my gtz, does the job but i just really got it for the wank factor. apart from that cant u just cut the right wire on the ecu? just mite have some flashing from the engine check light.
