NZVengeance wrote:thats the thing tho isnt the boost on the ct20b mechanically controlled so an ebc would not be of any use.
im not sure im just asking
NZVengeance wrote:right so an electrical feed from the ecu tells the actuator how much boost.
so when you hook up an ebc you are effectively bypassing the ecu's signal?
