Tube and fin i/c vs bar and plate
Postby Brick » Sun Feb 10, 2008 8:53 pm
Out of these 2 whats actually different and whats better?
Note this is for a race car (evo)
Brick
I know Kung Fu
Postby IH8TEC » Sun Feb 10, 2008 8:59 pm
tube and finn meant to be better. hence why i got one on my car. something about how the air flows through it smoother or something
Postby BlakeNZ » Mon Feb 11, 2008 8:00 pm
reality is you are unlikely to ever notice a difference between the two.
BlakeNZ
Postby matt dunn » Mon Feb 11, 2008 11:18 pm
BlakeNZ wrote:reality is you are unlikely to ever notice a difference between the two.
Kind of,
the biggest difference we found was the one of them blocked the airflow to the radiator and cause real overheating drama's.
After striking this on no less than 4 different race cars,
back to back testing on the focus proved it.
The cheap big ones flow heaps of air through the core and cool well,
but dont flow enough through to the radiator.
Postby fivebob » Tue Feb 12, 2008 12:23 am
Depends on the application. Bar and Plate will cool better so you can get away with a smaller I/C for the same cooling capacity, Tube and Fin will flow more air so it will have a lower pressure drop.
Postby barryogen » Tue Feb 12, 2008 8:35 am
matt dunn wrote:the biggest difference we found was the one of them blocked the airflow to the radiator and cause real overheating drama's.
so which one blocked radiator flow and which one didn't?
I assume tube anf fin is better as was already semi-stated?
barryogen
2ZZ Guru in training
Postby Brick » Tue Feb 12, 2008 5:06 pm
so if you had a race car for gravel sprints and hillclimbs, running factory turbo but bolt on mods, wat would you recommend...
Brick
I know Kung Fu
Postby BlakeNZ » Tue Feb 12, 2008 11:01 pm
thanks for your input Matt- i did not think of that aspect. very important on a circuit or hill climb car.
BlakeNZ
Postby Bazda » Tue Feb 12, 2008 11:51 pm
http://www.hybrid-power.com/images_prod ... cooler.JPG
The pic is of a bar n plate haha, but its acutally a fin and tube.
Postby SUBARUCONVERT » Fri Feb 15, 2008 6:11 pm
Kind of,
I aso found this on my subaru, the bar and plate one i use effects the radiator greatly
3ST150
SUBARUCONVERT
Postby Brick » Wed Feb 20, 2008 7:26 pm
so which one i better then?
Brick
I know Kung Fu
Postby 92mr2paddy » Tue Feb 26, 2008 1:50 pm
any good genuine brand intercooler will work best,, cheap ones are cheap for a reason, i personaly like the bar and plate as they also hav 'inner' fins (the good ones anyway) and you wont need a massive one for great power,, also the good brands dont have a 'huge' pressure drop anyway so u should be ok.
or if u think its going to affect the radiator put a couple of fans on it :)
92mr2paddy
Postby matt dunn » Tue Feb 26, 2008 8:03 pm
92mr2paddy wrote:or if u think its going to affect the radiator put a couple of fans on it :)
You realise that if your car has an overheating problem and you put a couple of fans on it,
the problem gets worse and it overheats more !!
The point is,
There is more to an intercooler than pressure drop and air charge cooling.
