fxgt 4agze
fxgt 4agze
Postby Tru3no20v » Sun Feb 10, 2008 11:20 pm
dunno if id even do it (good idea tho haha) but has anybody round here done a 4agze coversion into a ae82 fxgt.
kinda gatherd id need an engine, ecu and loom... posible gear box to although im not sure what a stock fxgt box can take. and yeh front mount.
oh and fuel pump??
a mates got a full aw11 sc i could buy as a doner car. :P
wouldnt think breaks would need to be done, and would the gze bolt up to the fxgt mounts
ae82 fxgt corolla
<<<-------- . . . the names old
Tru3no20v
Postby rollaholic » Mon Feb 11, 2008 6:58 am
i used to own an AE82 with a 4AGZE in it. was lots of fun, link and 12 psi! kinda wish i still had it actually, was a real sleeper.
from what i can remember the bottom rear mount had been moved slightly to fit the GZE, but i think the others were standard 82 mounts. although, whoever did the conversion used the original NA mounts and i if i recall correctly the GZE has beefier engine mounts - the car kept tearing mounts anyway. bit more twist than a bluetop i guess ;)
late model gze's are better, and its probably worth swapping the gearbox too - if for no other reason than that monstrous 3rd gear ;)
Postby THA SHZ » Mon Feb 11, 2008 12:59 pm
if you use the supercharged box then you will have to make a whole new rear engine mount , you will have to get the shafts shortened . if you use the mr2 box u will need to change the linkages and starter around to the opposite side , the fuel pump will need to be changed and u will have to do a bit of wiring as it wont be just plug and play 8)
But if you have a donor car it makes it alot easier , although the compression on the supercharged aw's are slightly different to the levins .
THA SHZ
Postby themaleman » Mon Feb 11, 2008 7:22 pm
my mate had a 4agze in his ae82, he used axels out of a supercharged mr2. (not the gearbox) im sure they wernt modifyed.
the engine side mount was a standard fxgt mount
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Tru3no20v » Mon Feb 11, 2008 8:01 pm
used the axels and mr2 box on put them into a standard fwd gze box?
hrrmm sound like a fun project haha. yee no big cuts for a fmic too id love it sleeper
ae82 fxgt corolla
Tru3no20v
Postby IH8TEC » Mon Feb 11, 2008 8:03 pm
dont think you have to modify them as long as you use the gze hubs
Postby Tru3no20v » Mon Feb 11, 2008 8:27 pm
gze hubs or aw11, is ther any difference.
i guess there would.
anybody got pics or nethin?
ae82 fxgt corolla
Tru3no20v
Postby THA SHZ » Wed Feb 13, 2008 12:55 pm
Tru3no20v wrote:gze hubs or aw11, is ther any difference.
mr2 hubs shoud be the same as ae82 , you dont want to lose the adjustable camber hubs from the ae82 , the levin and trueno ones are different , the levin and trueno shafts will have to be shortened , not 100 % sure on the mr2 ones , but before you use them , if you do , jack up your car with the mr2 shafts in it and take measurements and measure it through its suspension arc , they may look like they fit , like the levin ones but once you have them in and loaded up going around a corner they will blow inner cvs 8)
THA SHZ
Users browsing this forum: Google [Bot] and 17 guests
