Generic turbo monifold(although per engine)
Postby barryogen » Mon Feb 11, 2008 1:31 pm
I had a thought over the weekend and wondered why there isn't such a thing.
I'm meaning that the monifold would have a generic type flange where the turbo would sit, so that you could change whatever type of turbo you are using for one of a different type, by changing the adapter plate to suit the new turbo.
Now I realise that if this was a good idea then people would/should already be doing it, so what have I missed?
I realise that the adapter
a, would need to be fairly small to fit in any engine bay
b, couldn't possibly fit all turbo types
c, would need to flow suitably
a and b are fine, and should be able to get around, but I guess that c would be the show stopper, it would be the collection point for all the exhaust, and would need to be perfect.
your thoughts guys?
barryogen
2ZZ Guru in training
Postby NZVengeance » Mon Feb 11, 2008 1:45 pm
i think the biggest problem with something like this is that every cars engine bay is different. you wouldn't be able to sue the same shape manifold on a gt4 as you would on a evo or a wrx.
the next issue i see is. with a generic adapter plate which you woul then bolt a specific plate onto. where would the bolt go? because each turbo has a different bolt layout you couldn't get it to match up trough the specific flange then through the generic flange. see here
now i believe the reason the bolts go straight through the flange is because of the weight 15mm of thread isnt enough hence why they go through and have a nut. i could be wrong though
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
He who dies with the most Toys wins!!
NZVengeance
Postby barryogen » Mon Feb 11, 2008 4:09 pm
NZVengeance wrote:i think the biggest problem with something like this is that every cars engine bay is different. you wouldn't be able to sue the same shape manifold on a gt4 as you would on a evo or a wrx.
heh, thats why I said "per engine" as in say for the 3sgte you have one, for 4g63 you have one etc.
NZVengeance wrote:the next issue i see is. with a generic adapter plate which you woul then bolt a specific plate onto. where would the bolt go? because each turbo has a different bolt layout you couldn't get it to match up trough the specific flange then through the generic flange. see here
I was meaning header, generic flange, tube(probably approx 1" long), "correct" flange.
barryogen
Postby NZVengeance » Mon Feb 11, 2008 5:07 pm
yea but like the header may not fit in a mr2 like it will in a celica or caldina
Albert Einstein
NZVengeance
Postby evil_si » Mon Feb 11, 2008 6:31 pm
,mainly because each application has different fitment issues,
subaru to mitsi turbos sit differently as do ihi to garrett turbos,
some the turbine housing is reversed etd
ive done a couple with t3 and tdo5 multi flanges, but they are more of a pita than anything,
evil_si
Postby barryogen » Tue Feb 12, 2008 8:17 am
sweet as, I gathered that there would be a good reason not to make/use them, and once again Toyspeed has sorted out my thoughts. :)
barryogen
Postby Stealer Of Souls » Tue Feb 12, 2008 8:36 am
Tee hee..
More like Toyspeed has once again shown that, as the average "joe", we aren't creative or skilled enough to make a solution that may work.
'86 AE85.5 Levin
Stealer Of Souls
