difference between ST and BT cam drive sprockets?
Postby matt dunn » Mon Feb 11, 2008 11:27 pm
Is the cam drive wheel on the crank different between
a Silvertop 20V and a Blacktop 20V?
Here's what I found.
I line my engine up with the notch on the cam drive sprocket with the dimple on the oil pump housing like you are meant to do to do cam timing,
and the engine is not at TDC.
This is a Blacktop oil pump and a Silvertop cam drive.
With a Silvertop oil pump and a Silvertop cam drive,
the same marks line up and it is TDC.
The keyway is fine and in the correct place,
as when you fit the front pulley, the TDC marks on it are correct?
matt
Postby 20v_rollaboy » Tue Feb 12, 2008 12:00 am
So with the BT oil pump, ST sprocket, and front cover fitted, the marks are correct on the cover? (with dimple and sprocket lined up)
Are the dimples on the oil pumps in the same place?
20v_rollaboy
Postby matt dunn » Tue Feb 12, 2008 7:19 pm
I do not know, but I suspect it is not in the same place,
which would also mean the cam drive sprocket is marked in a different place in relation to the keyway,
meaning two different sprockets??
Postby 20v_rollaboy » Tue Feb 12, 2008 8:33 pm
Sorry I cant be of more help, Ive only ever dealt with ST's.
But I would say use the original sprocket and make sure the engine is at TDC by sticking something down the plug hole, and double checking on the sprocket cover.
20v_rollaboy
Postby Mr Revhead » Tue Feb 12, 2008 8:35 pm
i dont think matt is after help to time his engine :wink:
more trying to establish the exact difference between two parts :wink:
Postby matt dunn » Tue Feb 12, 2008 11:53 pm
Mr Revhead wrote:i dont think matt is after help to time his engine :wink:
Exactly,
So maybe Mr revhead can puch out some part numbers,
I dont have acess to a cam drive off a blacktop,
so want to know before I go and buy one,
if it will just be the same as the ST one,
or if it will in fact be slightly different.
Matt
Postby sergei » Wed Feb 13, 2008 12:44 am
From my experience with using ST sprocket on BT:
1) ST sprocket is skinnier (1 ~1.5mm thick washer seems to fix misalignment)
2) It is off by about half of tooth.
I assume it is off because of the difference in oil pumps.
I learnt it hard way as the performance was poor for no apparent reason, similar to blue-top, which the BT replaced, so after checking everything, I decided to do screwdriver test and figured that ST sprocket is off.
The reason why I used ST sprocket is that I have destroyed BT original sprocket in order to remove it to replace the seal (they have this habit of getting stuck big time), this all happened in weekend and needed car to be running ASAP so I resorted to ST sprocket.
Half of tooth makes huge difference in performance in those engines.
Postby Mr Revhead » Wed Feb 13, 2008 11:11 am
they are a different part number.
Postby 85AW20v » Thu Feb 14, 2008 8:40 pm
And aren't the timing belts different in length as well with the BT being 1 tooth longer?
See ya
Simon
85 MR2 20v
85AW20v
Postby matt dunn » Thu Feb 14, 2008 10:59 pm
Simon85MR220v wrote:And aren't the timing belts different in length as well with the BT being 1 tooth longer?
Yes, but that is in the tensioner location,
which is why i used a BT oil pump as it made the belt the right length,
where a ST one needed a little mod to get the belt right.
Postby slighty_sykotic » Fri Feb 15, 2008 9:37 am
Yes they are different.
I rebuilt a BT and like Sergi i had to use another pulley, as I destroyed my BT due to it being stuck.
Put a ST one on, lined up marks, put cam belt on. Engine started and idled ok, but it would rev really slowly. Like taking 3 or 4 seconds to hit high revs after going wide open throttle (just in neutral).
Put belt off and on a few times, until I decided to check the marks with a screwdriver, and sure enough, was a tooth or two out (can't exactly)
slighty_sykotic
Postby matt dunn » Fri Feb 15, 2008 8:52 pm
Mine ends up exactly 1/2 was between teeth.
Anyway, make enough power as is,
so adjustable cam wheels can be next seasons project.
