So now an explanation.
there is a tube which had the pod filter in it, just big enough to fit the pod in so the air cant pass along side it.
That tube is housed inside a box (Stainless or aluminum) filled with water and antifreeze (not a huge amount mabey a couple of litres.
Attached to the outside of that housing is some peltiers*
perltier cool the water to a very cold temp whcih keep that cylinder that houses the pod very cold which means all the air that comes in there is cooled
*Peltiers are a small square device that get very very cold on one side and very very hot on the other. they are used in samll fridges and the like.
