Smaller Alternator for Beams 3sge (altezza)
Postby nz_climber » Thu Feb 14, 2008 8:38 pm
Hi everyone, like the title says, I am after a smaller alternator for altezza 3sge. As the one on there is massive, and because its only going in a lotus replica I only need it to power the engine and lights - no stereo or fancy bits.
Doesn't matter if it don't bolt straight on, as I can get brackets made, and will be mounted where ever I get free space (could be either side at this stage)
cheers in advance
nz_climber
Postby strx7 » Thu Feb 14, 2008 8:58 pm
even though the factory one is massive, they are barely upto the task.
Re: Smaller Alternator for Beams 3sge (altezza)
Postby Jason T » Thu Feb 14, 2008 9:20 pm
nz_climber wrote:Hi everyone, like the title says, I am after a smaller alternator for altezza 3sge. As the one on there is massive, and because its only going in a lotus replica I only need it to power the engine and lights - no stereo or fancy bits.
cheers in advance
Make this sucker fit http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Other-accessories/auction-140681064.htm
Fixing Toyota's since '87
Jason T
Postby RomanV » Fri Feb 15, 2008 12:47 am
What sort of clearance issues do you have?
You could run a celica alternator+bracket, as this puts the alternator higher up on the exhaust side of the engine.
MR2 alternator + bracket wont fit under the intake manifold.
You can borrow mine to see how it fits up if you like.
Postby nz_climber » Fri Feb 15, 2008 4:37 pm
Cheers Roman, but this is all happening in the south island, but thanks anyway, I not sure if there will be clearance issues and won't know until I get the engine chassis and steering all in, at the moment I more just wanting to reduce weight etc (if there was an easy option for replacement)
nz_climber
Postby gepsk8 » Fri Feb 15, 2008 7:02 pm
4age, or simalar would be ok.
but of the amount of effort it take to fit it wouldn't save u enought kg's to worry about, spend the money on something like engine.
O272754663
gepsk8
Postby matt dunn » Fri Feb 15, 2008 8:56 pm
Go for a Starlet alt, I think around EP90 model,
they are quite small,
other than that, there are forklift alt's available that are same style and brand as the toyota one's but just a lot smaller and dearer.
