blow off valves
blow off valves
Postby samlloyd » Sun Feb 24, 2008 4:30 pm
Just got a question in relation to bovs.
My car was on the dyno on friday, after getting a few things done to the motor (rb30det). The tuner says its getting heaps of compressor surge. Its a small turbo for the size of the motor; a T3/T4 .63exhaust (thats all i know at this stage :roll: )
Its got a genuine blitz sequential job on it at the moment. My tuner reckoned to run a standard type bov aswell as the one thats on there. Does anyone else do this. Would this just be because the standard ones have a lighter spring in them or something? How would a standard one be more efficient? And can i use any type of standard turbo vehicles bov?
Also having troubles with the internal wastegate not holding boost, i think the spring in it is just not quality enough. Currently 160kw at 3800rpm, then boost starts getting out of control there.
Car is still on dyno, will be on it all tomorrow.
samlloyd
Postby IH8TEC » Sun Feb 24, 2008 4:55 pm
if your car does not have that good a vaccuum (like my car) then yeah a lighter spring helps, my bov's are slightly open at idle, but on throttle close up good. i beleive it can be a problem however if it's afm. not sure what your one is?
can you adjust your blitz one? do you run the line straight from the intake manifold? on it's own line.
and what form of boost control are you using? just the spring?
Postby samlloyd » Sun Feb 24, 2008 5:03 pm
Its just had a link G3 installed, so no afm anymore. Boost control done by computer/wastegate. I think there is a Allen key type screw on the top, maybe ill try loosening it off?
I dont think it is on its own line but will check, (was installed before i bought car)
samlloyd
Re: blow off valves
Postby Crucible » Sun Feb 24, 2008 6:47 pm
smithers wrote:The tuner says its getting heaps of compressor surge. Its a small turbo for the size of the motor; a T3/T4 .63exhaust (thats all i know at this stage :roll: )
ssq copies and genuine HKS ssq bovs dont vent very well....if any at all!. I had one on my car and got rid of it because it was surging quite bad. Others i know have had the same problem aswell.
Crucible
Real Life Mechanic
Postby samlloyd » Sun Feb 24, 2008 7:04 pm
Mines more like this, without the trumpet extension
Its not like this,
If i find another bov ill try swapping it and see if that helps
samlloyd
Postby Dell'Orto » Sun Feb 24, 2008 8:57 pm
Might be that the Blitz one just can't dump enough air, they've got quite a small piston so that could be the issue.
Re: blow off valves
Postby AJz » Mon Feb 25, 2008 12:11 am
True-No-Turbo wrote: ssq copies and genuine HKS ssq bovs dont vent very well....if any at all!. I had one on my car and got rid of it because it was surging quite bad. Others i know have had the same problem aswell.
Interesting you say that. Quite a few people recommend them as being one of the top because of the way they work. Baring in mind the genuine HKS would be of higher quality compared to the "no name" SSQV ones.
I used to run one i bought off Al @ Driven. Worked fine for me with standard boost. I got rid of it cos the noise drove me nuts after a while. Back to the factory one atm.
I had vtax :(
AJz
Postby Bumpy » Mon Feb 25, 2008 5:26 pm
I have a genuine hks ssqv on my starlet, and those copies are S$%T!
I have never had any probs with mine and I've pulled it apart a couple of times over the 5 years i've had it to have a tootuu.
The only reason you'll be getting compressor surge is because the blow off valve isnt opening up enough, just find another vacuum source or get another blow off valve ...
Bumpy
Postby tsoob » Mon Feb 25, 2008 11:25 pm
i have the same blitz one on mine it is going on the dyno tomorrow arvo so will see if i have the same probs or not.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby samlloyd » Tue Feb 26, 2008 7:14 am
Mines off the dyno and im picking it up today. The internal wastegate isnt working so well so boost does spike. The remedied it a bit and got the boost curve a bit flatter. But it really does need boring/external.
180rwkw at 4k though :)
samlloyd
Postby TRD_ZERO » Wed Feb 27, 2008 8:59 pm
OK maybe its just my run of bad luck but ive had two of those blits ones they are the super sound version......they used to open up hecticly on idle and gave me bad leaks( you really notice it when you run afm). so i replaced it with a rebuilt one and it just jammed open. Thats two of the exact same bov........ so i went all out and paid top$$ for a new genuine hks ssqv as in the bottom pic and had no issues, that design is great i can definatly reccomend them.
TRD_ZERO
Postby tsoob » Sat Mar 01, 2008 6:11 pm
it makes a little surge now was unsure its only if you take your foot off the gas slowly on boost but if you takt it off fast no probs.
Any luck with yours?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby samlloyd » Sun Mar 02, 2008 12:04 pm
I havnt had much of a play with it. I got the internal wastegate bored out by roughly 9mm. I can hear the turbo chatter if you rev it up in neutral, with no load on the engine, but im not sure if it does it when it has some load on it and the b.o.v is actually venting.
samlloyd
Postby escortman » Sun Mar 02, 2008 9:45 pm
do u have it set to hard? i played round wit mine 2day seems to be better now, had it set to hard
4x4 toyota blizzard offroader
escortman
Postby evil_si » Sun Mar 02, 2008 10:38 pm
who was your tuner? jason at infomotive?
evil_si
Postby samlloyd » Mon Mar 03, 2008 7:19 am
yes
samlloyd
Postby cat007 » Mon Mar 03, 2008 11:00 am
What position is best for a BOV? Should it just be T'd into the pipe like this
Or should the BOV pipe be like a Y like this
That way the shock way bounces back INTO the BOV - but the air leaving the turbo has to do a 180degree turn to exit through the BOV
Or should the BOV be facing the other way, so the air leaving the turbo can go straight out the BOV
OR - does it not matter?
What are everyone's thoughts?
Postby touge rolla » Mon Mar 03, 2008 3:23 pm
I don't think it matters. Either way it's easier for air to flow through your bov than backwards through the turbo.
touge rolla
Postby samlloyd » Mon Mar 03, 2008 9:32 pm
It doesnt really matter how the b.o.v is mounted, the rate at which pressure waves move is pretty quick.
just confirming this is my b.o.vImage
Do i want the top screw adjusted quite far in?
samlloyd
Postby tsoob » Tue Mar 04, 2008 9:19 am
if you screw it in it goes harder, mine is the same one
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
