Hi all. I know this is my first time posting and I know my car is a piece of crap but aside from taking it to a mechanic and forking out this was the only other place to ask that I could think of. Thanks a lot for any help!
So i've got a 1989 Corolla with a 1.3 carby (2E) in it. I've been away from 3 months and haven't used it and it ran fine before but now the idle is very weak and rough (sometimes stalls) and it has little to no power once you get moving. If you go for a bit then stop it'll stall and it's also pretty hard to start. When you rev it in neutral it pumps out a lot of grey smoke and the engine itself is moving about quite a bit. It's done about 250k so it's pretty old and tired but i'm just wanting to get it driving around again. From these symptoms does anyone know if it sounds like the carb needs adjusting, spark plugs are old, air intake is blocked or anything like that? Not really too clued up on the ways of the carburettor.
Any help would be much appreciated.
