Whats everyone using for turbo oil return lines?
Postby RedMist » Sat Mar 01, 2008 7:39 am
For that matter, what are everyone using for oil feed, oil return, water feed and return lines?
My fabricator suggested using a high temp rubber line between two mild steel pipes. However due to the proximity of the turbos I suspect it will become brittle very quickly.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby strx7 » Sat Mar 01, 2008 7:58 am
feed is a little hardline to a banjo at each end, braided flexi in the middle.
return is steel hardline with a approx 100mm of hydrulic hose in the middle of it.
water lines are hardline with some rubber water hose in the middle
Postby IH8TEC » Sat Mar 01, 2008 9:28 am
i use -3 braided teflon hose for the oil feed.
return is some 19mm id stainless, made into a about a 120deg angle, then with high temp 19mm id hydraulic line between that and the 19mm id steel pipe off the sump.
i dont run water.
Postby evil_si » Sat Mar 01, 2008 10:09 am
on my rx7 ive got stanless braided feed hose, and a steel drain pipe with a stainless braided flexi section.
on the 2jz altezza each turbo has a stainless braided feed hose, and 2 steel drain pipes down to a rubber joiner about 80mm of high temp oil hose onto the factoy Y return to sump
water lines, i usually get 3/8mm fuel hose and use push on fittings banjos etc.
evil_si
Postby Lloyd » Sat Mar 01, 2008 11:08 am
Just high temp/high pressure rubbing hosing for both. Depends what you want to spend, though I'm guessing this is the sort of thing you aren't wanting to go light on
Postby Akane » Sat Mar 01, 2008 11:22 am
Feed line is braided line with L shape connector.
Drain is a high temp rubber pipe, which is braided internally. it has "LOL" printed on it, blue in colour. still cooks itself tho after a while.
Postby tsoob » Sat Mar 01, 2008 11:46 am
ive got braided feed and high pressure rubber return no probs at all so far.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
