Valve stem seals?
Valve stem seals?
Postby tsoob » Sat Mar 01, 2008 6:20 pm
When i am engine braking down hills itere a puffs of white somke coming out my exhaust any thoughts?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby MRDRFT » Sat Mar 01, 2008 7:13 pm
valve stem seals normaly blow smoke at start up or if you idle 4 a long time then take off,i dont have any in my car and i have never had a problem on the hills
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby Dell'Orto » Sat Mar 01, 2008 8:04 pm
White smoke is usually oil burning without going through the combustion process, so maybe an oil seal on the turbo? How much white smoke are we talking?
Postby rollaholic » Sat Mar 01, 2008 8:42 pm
i tend to associate white smoke with water personally!
(though i suppose it should more rightly be called steam)
Postby cat007 » Sat Mar 01, 2008 9:50 pm
I thought blue smoke was oil being burnt in the combustion chamber and white was oil burnt after the combustion chamber, such as a turbo ring/seal gone etc?
Postby tsoob » Sun Mar 02, 2008 12:16 am
not a huge ammount of smoke white smoke tho when i come on to vac when going down the motorway earlier today and sam said he saw it wehn he followed me tonight.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
