ae101 drivers side engine mount, any tricks?
Postby Mike- » Sun Mar 09, 2008 9:19 am
ok so im tryna remove the engine mount but i cant undo the through bolt because of a rubber 'guard' above the nut which doesnt allow room for a spanner or a socket, so how does everyone else go about it?
car is a levin
Mike-
Postby tsoob » Sun Mar 09, 2008 11:58 am
sounds like you need more tools have you got a jijjly bar or a long extension, or can you remove the rubber?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Mike- » Sun Mar 09, 2008 12:22 pm
not too sure what a jijjly bar is, and its a bit tight for an extension
Mike-
Postby Mike- » Sun Mar 09, 2008 12:35 pm
problem solved, i just loosened off the other mounts and jacked it up some more
Mike-
Postby AceSniper » Sun Mar 09, 2008 1:06 pm
norm you would just undo the two nuts from under the car that mount it to the engine stay
AceSniper
