gtt intake question
gtt intake question
Postby gleem » Mon Mar 10, 2008 8:22 pm
i've taken my airbox out and im not too sure what to do with this pipe, do i just leave it hanging there or what, it makes a real annoying sucking noise and when you put your thumb over it it turns the car off >_<
Am i ment to put this in the new intake piping or intercooler piping? Also that plug that goes in to the airbox what should i do with that just leave it dangling there?
cheers!
http://www.youtube.com/watch?v=bi_7wuIdP08
gleem
Postby 99gtt » Mon Mar 10, 2008 8:44 pm
you need to put a breather tank in there ,same as a catch can with a filter on it . That pipe is your cold start. Just tie the temp sensor up some where or if you want you can plum it in but not necessary.
SOON TO BE 500 HP
99gtt
Postby gleem » Mon Mar 10, 2008 8:54 pm
so i just chuck a breather filter on and ditch the rubber hose?
gleem
Postby rodstr » Mon Mar 10, 2008 8:55 pm
idler feed, 15mm breather filter should fix that problem. dont think you need a catch tank as you wont be catching any oil
edit: yes and ditch the hose
rodstr
Postby 99gtt » Mon Mar 10, 2008 8:57 pm
Try it it might work but i think it needs to be contained
SOON TO BE 500 HP
99gtt
Postby rodstr » Mon Mar 10, 2008 9:12 pm
excuse my ignorance but what needs to be contained? :roll:
rodstr
Postby 99gtt » Mon Mar 10, 2008 10:45 pm
as in an enclosure . If you just put a filter on 1, you will have constant hissing noise 2, idle fluctuation
SOON TO BE 500 HP
99gtt
Postby rodstr » Mon Mar 10, 2008 10:50 pm
oh right ok, didnt notice any hissing on my one in cabin, not even that loud at all, only on startup when cold, goes away in a few mins.
rodstr
Postby bubz » Tue Mar 11, 2008 3:31 am
I have plumbed it into my intake hose and also connected the Temperature sensor.This is how I have mine:
1997 Gtt Caldina Tiptronic
bubz
Users browsing this forum: Bing [Bot] and 14 guests
