4agte head work
4agte head work
Postby tsoob » Tue Mar 11, 2008 10:50 pm
ive gotta pull my head off again, i cooked it and have either done a gasket or a crack not sure yet, my question is are there worthwhile mods to do while i have the head off, im going to do the valve stem seals as it is sucking oil down at the high rpm rev range, is it worth porting or getting better cams springs etc??
Thanks,
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby tsoob » Tue Mar 11, 2008 11:19 pm
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby matt dunn » Wed Mar 12, 2008 12:17 am
just be aware of the cost of fitting the oversize valves to a head,
there is more than just the cost of the valves.
Postby tsoob » Wed Mar 12, 2008 12:25 am
yeah dont think ill bother with that anyone use steel head gasket> worth the extra money?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby flygt4 » Wed Mar 12, 2008 6:58 am
use the TRD 3 layer steel one, they are very good and its one less thing to worry about. my engine had one and it run 20-22psi for extended periods of time pretty happily.
flygt4
Postby IH8TEC » Wed Mar 12, 2008 7:26 am
adn mines been raped with a std one and it's fine 8) think matt had a std one on the old 20v turbo in his track car. and that head gaskit on trademe seems really expensive, might pay to contact warrick on that one
Postby AceSniper » Wed Mar 12, 2008 3:33 pm
TRD ones are like 100$ new from toyota... for the $$ worth while
AceSniper
Postby matt dunn » Wed Mar 12, 2008 9:00 pm
I still use the std 20V one in my current 440hp atw 7AGTE.
In fact, the engine builder recommended that over the TRD type.
I had a TRD metal one for the 1600 that I built, but looked at it and did not like it, so i did not use it and re-sold it.
I could not see what seals in between the 3 layers of metal,
and dont like steel gaskets anyway.
Matt
Postby Mr Revhead » Wed Mar 12, 2008 9:58 pm
that TRD gasket on trademe is well over priced!
Postby tsoob » Wed Mar 12, 2008 10:30 pm
thanks warrick ill email you once i have the head off and have a shopping list.
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby tsoob » Mon Mar 31, 2008 11:51 pm
head is off, gasket looks fine so suspect the head, who knows the cheapest (read:FREE or very close too) place for a pressure test,
i think its rubbish the head and replace but dont know for sure dont want to waste money to get a definite "yeah its f'd" answer..
while on this topic are arp head studs worth the money?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby bluemaumau » Tue Apr 01, 2008 5:25 pm
yes. get them 41 does em cheap
Postby TRD_ZERO » Tue Apr 01, 2008 5:29 pm
I dont know about free or cheap but id go to the cylinder head shop on sunnybrae road he knows his 4ages, speak to him.
TRD_ZERO
Postby IH8TEC » Tue Apr 01, 2008 6:38 pm
they are only necessarily if you plan on taking the head off much. standard bolts are cheap i beleive.
me running so much boost am waiting for something to go wrong :lol: so i have them incase i have to take head off and put on lots.
Postby rollaholic » Wed Apr 02, 2008 9:20 pm
IH8TEC wrote:they are only necessarily if you plan on taking the head off much. standard bolts are cheap i beleive.
they look cool in project thread photos!
Postby tsoob » Wed Apr 02, 2008 10:05 pm
Those are both extremely important facts to consider especially the photo bit! lol
I guess that means they are reusable brendon? how many times, i dont really want to take the head off lots but if i have another problem....
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby IH8TEC » Wed Apr 02, 2008 10:28 pm
i'd say re-useable as much as you need, as long as you give them a good look over each time, and mainly check the threads on the nut as well as the stud before you re-lube them, think they are lubed on the nuts.
