205 GT4 brakes replacement question
Postby DaVe0r » Sun Mar 16, 2008 12:07 am
Hey ppls
after jacking up the celica trying to find the dam clunking when reversing and the bashing sound when going over any bumps, (turns out the exhaust job was a botch up as it hits the gearbox when the motor moves)
i did my best to check the Super strut out ..no movement or play ?? so may be not that..BUT while under the car
i noticed that the rotors are lipped on both sides..easily 1mm and have some nice grand canyon makes on one rotor
now rather than getting them machines back again..where do i buy new slotted rotors for the GT4?? i looked at DBA web site and they are not listed..
does TRD make something for this??? im going to also upgrade the pads at th same time too
heres a pic of the exhaust job anyways :( (that i didnt do btw)
Toyota Celica GT4, 255Hp of Factory goodness
Ford Laser S KL-ZE Swap Track hax
Mazda Astina GT 138whp N/A *Gone*
DaVe0r
Postby Zak » Sun Mar 16, 2008 7:29 am
Toyota should do new ones, they are a little bit more than the aftermarket items though.
Most of the rotors I've priced up have been $144+GST ea, but depending on the model, and if you go through rev head it might be different.
Zak
Postby Trls250s » Sun Mar 16, 2008 8:37 am
They are expensive no matter where you get them from as they are veined. Make sure you get a left and a right one as the veins are directional.
If the clunking noise is comming from the front then it will be a small spacer in your superstrut. But if your sure its your exhaust then it will be your exhaust (looking at it)
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
