by KinLoud » Sun Mar 16, 2008 8:56 pm
I strongly recommend buying a complete donor car with a 20v motor. This means you will have every little bracket, plug and hose that you will need.
Also you will have the bigger brakes, rear disk brakes and the higher rate springs and swaybar. I'm sure you can buy a complete car with the engine still running for less than $500 ( mine was $300 I think).
Bought a damaged 1992 AE101 Trueno 4age 20v silvertop C52 gearbox
Bought an AE101 Marino 4afe C50 that had a seized engine.
We (me and Ewan, 10k20v) bolted the whole front subframe and suspension from the Trueno into the Marino (brakes, suspension, gearbox and motor) also swapped the brake booster and bias valve.
Also swapped the rear brake,s handbrake cables, hubs and swaybar across. Should have swapped the steering rack so the 20v steering vacuum lines had somewhere to plug into (it runs fine with these lines just blocked off!).
The 20v engine loom plugged straight into the Marino body loom. There was even an unused plug on the Marino loom just waiting to plug into the 20v aircon idle up valve!!!
Only wiring needed was a jumper wire from the 20v loom to the fuel pump relay wiring so the pump worked correctly.
Easy! But sure helps to have the complete donor vehicle!
Total cost $1200!!!!! for everything including the cars!
Let me know if you want more details.
Ken
Ham
021 408 863
