4AGZE (non-DLI) into a orginaly DLI car
Postby Calvin » Mon Mar 17, 2008 12:26 am
Had a search but couldnt find exactly what i was after. (only found the reverse http://www.rollamods.com/tech/ae86gzetacho.pdf)
I am wanting to know the method in hooking up a Distibutor ign system to a DLI tacho.
Motor is: 4agze bigport (AW TYPE)
Car: 1990 AE92 GTZ (facelift) originally MAP GZE
The tacho is currently hooked up but it bounces and im unsure how accurate it is..
Calvin
Postby gepsk8 » Mon Mar 17, 2008 7:57 am
use a normal tacho? out of 4age levin(got 1 if u need it?)
O272754663
gepsk8
Postby Calvin » Mon Mar 17, 2008 12:19 pm
cheers. will get in touch via txt :)
Im assuming it will plug up with no modification? or are the plugs different?
Calvin
