Oil around the bottom of the Dizzy?
Postby Calvin » Sun Mar 23, 2008 9:02 pm
I noticed today that there is alot of oil build up on the bottom of my distributor and around the front of the block.
Would this suggest that the Distributor needs a new O-Ring??
What else could be causing this issue?
Motor is a 4AGZE BIGPORT
Calvin
Postby lucasthefallen » Sun Mar 23, 2008 9:04 pm
could be the main dizzy o-ring, but could possibly be an internal leak from the dizzy. unfortunatly, thats not uncommon
Need Service or Repair work done? send me a PM
lucasthefallen
Postby Bumpy » Mon Mar 24, 2008 1:25 pm
Not uncommon, but an easy fix though.
An o-ring will be less expensive than a new dizzy ...
Bumpy
Postby d1 mule » Mon Mar 24, 2008 2:03 pm
there are 2 "O" rings tho if its the main one its easy but if its the internal one im fairly sure the dizzy reeds to be partly ripped to bits
d1 mule
Postby Calvin » Tue Mar 25, 2008 8:25 am
Cheers guys, ill look into it. Hopefully just a fcuked O-Ring :)
Calvin
