Can i fit 4age 16v exhaust manifold to a 20v?
Postby ke25sr » Thu Mar 27, 2008 10:26 pm
About to do a new 2 1/4 mandrel bent system on the AW and have access to a set of 16V extractors.
(i can also supply these bends at good prices incl donuts pm for details)
So will they fit?
ke25sr
Postby flygt4 » Thu Mar 27, 2008 10:33 pm
pretty sure they are very different as any headers i've seen can only ever be used for one or the other.
flygt4
Postby Mr Revhead » Thu Mar 27, 2008 10:54 pm
well.....
to fit a 20v header to a 16v you slot the holes.....
so to fit a 16v header to a 20v, logic dictates you slot the other way....
but logic also says its not the best idea...
what 20v have you got?
i cant recall the size of the 16v exhaust ports off hand.
but the vlack top ports are the biggest of them all. so fitting a 16v header wouldnt be too flash....
cant remember if the ST ports are smaller than the 16v or not....
Postby ke25sr » Fri Mar 28, 2008 7:58 am
Its a B/T So its prob not a good idea.
ke25sr
Users browsing this forum: Bing [Bot] and 6 guests
