fx gt wrote:have a 1991 corolla wagon ae92.
i have put a 4age into it and the altenator is only reading 9 when tested with multimetre.
also the batt light on the dash dosnt work.
is this a commen problem?
also does this light need to be working to complete wiring systum?
the alt wont work the loght on the dash unless there is power to the ignition wire on the alt to turn it on.
With a multimeter you should have 12v on all the wires that go to the alt with the key on,
with a test light one should glow dim and the others all should be bright.
