single throttle body> quads
Postby NOLAW » Sat Mar 29, 2008 11:25 am
im in the process of changing from a single throttle body to blacktop quads on my 16v, my question is can a swich the throttle positioning sensor from the single throttle body onto the quads? or do i have to change the plug to suit the sensor on the quads?
any help would be greatly appreciated
NOLAW
Postby Celica RA45 » Sat Mar 29, 2008 12:07 pm
you will need the black top tps to make these work and after market ecu as well ,wiring the tps will be different as well
Celica RA45
Postby NOLAW » Sat Mar 29, 2008 12:26 pm
oh ok, cheers, yeah iv got a link g3 which i had recently wired up so will there be much wiring to change or is it just a matter of changing the plug?
NOLAW
Postby NOLAW » Sat Mar 29, 2008 10:27 pm
any more opinions or did he hit the nail on the head?
NOLAW
Postby gepsk8 » Sun Mar 30, 2008 1:02 am
plug should be same, depending on which engine and yaer the single throttle off.
O272754663
gepsk8
Postby matt dunn » Sun Mar 30, 2008 10:34 am
nope will need a rewire from memory,
as the quads throttle shafts rotate the other direction, and so the pins in the plug are reversed, i.e. the earth that was at one end is now at the other.
Dont remember what model I struck it on, but it can happen.
Postby NOLAW » Sun Mar 30, 2008 11:09 am
ohk im not sure what year its off but il try it out when i see ma car again and see how it all works out, cheers guys :D
NOLAW
Postby 3T-Rona » Sun Mar 30, 2008 12:11 pm
pretty sure yours should be the same as your motor is a reasonably l8 model 4AGZE (Small port, CAS)
you'll have to use ur TPS as the 20V turns the wrong way
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby NOLAW » Sun Mar 30, 2008 1:39 pm
oh so would i actualy be better off using the TPS off my single thottle body rather than the one off the quads?
NOLAW
Postby matt dunn » Sun Mar 30, 2008 9:01 pm
NOLAW wrote:oh so would i actualy be better off using the TPS off my single thottle body rather than the one off the quads?
No what were saying is on the quads you must use a 20V TPS as they are not interchangable with 16V
and the 20V tps uses different wiring to the others.
Postby QikStarlie » Sun Mar 30, 2008 9:27 pm
yeh use 20v tps. 16v plug will fit, pins are back to front, thats all. just swap them over in the plug. easy.
QikStarlie
