by KinLoud » Sun Mar 30, 2008 12:46 pm
My experience of bolting AE101 disk rear onto AE101 drum brake car...
Easiest was to bolt the whole rear subframe across:
- subframe
- hubs
- disks and calipers
- handbrake cables (you will need these from the disk rear)
All as one unit.
It can be a real pain to just do the hubs without the subframe. This is due to the big bolts that connect the hub to the track arms often being VERY difficult to take out!
You will also need to swap the brake bias valve (in the engine bay on the firewall) to give the correct brake bias with rear disk brakes.
viewtopic.php?t=51136&highlight=brakes
Ken
Ham
021 408 863
