4agze abv vaccum lines
Postby gepsk8 » Sun Mar 30, 2008 12:37 pm
theres two connections on abv where do they go?
top ? inlet manifold? when abv mod done?
botttom? inlet manifold?
what one goes it vsv abv switch?
O272754663
gepsk8
Re: 4agze abv vaccum lines
Postby matt dunn » Sun Mar 30, 2008 5:11 pm
gepsk8 wrote:theres two connections on abv where do they go?
one goes no where, is just the vent for the other side of the diaphram,
the other from memory is to boost pessure so somwhere on the inlet manifold.
Postby Rick » Sun Mar 30, 2008 6:07 pm
Postby gepsk8 » Sun Mar 30, 2008 6:48 pm
cheers matt so one nipple is just for venting,
so if anyone can tell me what nipples for what the would be great?
top nipple does?
bottom nipple does?
O272754663
gepsk8
Postby matt dunn » Sun Mar 30, 2008 8:56 pm
that pic of the stock system is incorrect.
The blue VSV is the vent's for the s/c bearings, and is on when the S/C is on.
Postby Rick » Sun Mar 30, 2008 9:53 pm
matt dunn wrote:that pic of the stock system is incorrect.
Picture looks fine to me.
The VSV for the s/c bearings vent is brown in colour, and the plug for it is grey, not blue. and lives just on top of the supercharger.
The ABV VSV is blue with a blue plug
The fuel pressure reg VSV is brown with a brown plug
Postby matt dunn » Sun Mar 30, 2008 10:56 pm
Rick wrote:Picture looks fine to me.
been a while since i played with a s/c setup,
but i think u may be right.
Postby gepsk8 » Mon Mar 31, 2008 5:57 pm
anyone know what side abv is the vent?
what is the control?
O272754663
gepsk8
Postby Rick » Mon Mar 31, 2008 7:23 pm
The small pipe sticking 90 deg out from the body is where the vacume line is connected to, not the tiny angled down pipe thats just a vent.
If you suck on the small pipe it will move the spring loaded plunger.
Postby gepsk8 » Mon Mar 31, 2008 7:36 pm
O272754663
gepsk8
