st215 brake upgrades
Postby matty_j24 » Tue Apr 01, 2008 8:34 pm
hey im in the process of changine a few things to my gtt and figured while it was off the road and i was getting it ready for a re cert i would look into a brake upgrade has anyone done or knows or anyone that has fitted st205 gt4 celica brakes and calipers? any info or any other upgrades anyone has done would be choice thanks as i hope to be able to slow down when its all done :)
matty_j24
Postby matty_j24 » Thu Apr 03, 2008 12:00 pm
yes, no ?
matty_j24
Postby WCKWGN » Thu Apr 03, 2008 3:08 pm
i have seen a set on the net ex austalia - 6 pot calibers and slotted larger discs , braided barke lines etc pretty grunty looking
was from memory around $2600. Brembo / Wilwood will have some options avavilable no doubt. just depends on what how much moneys you have to put into them
WCKWGN
Postby matty_j24 » Thu Apr 03, 2008 9:35 pm
yeah that would be quite cool i wonder if they would clear my 16" te37's tho they sit quite close to the calipers
matty_j24
Postby WCKWGN » Fri Apr 04, 2008 11:02 am
WCKWGN
Postby Prymal » Fri Apr 04, 2008 6:41 pm
talk to wagonist on toymods in australia - hes upgraded a caldina with st205 4 pots with success
Same proicess as you use to upgrade St185 or Aw11 to st205 discs and rotors ..
5mm spacer , caliper mounted to opposite side of strut . machine rotor to 305mm diameter , custom brake lines - and longer landcruiser studs and your basically there.
I used the same process on my St185 group A to great effect ..
now i have factory fitted ones on my st205 group A
Prymal
Users browsing this forum: Bing [Bot] and 23 guests
