3SGE alternator into RA28 charge light issue...
Postby Mr_procrastination » Wed Apr 02, 2008 8:04 pm
So the 18RG is gone and the 3S is in.
New Alt is in and charging with and external Voltage Reg gone.
Wires are;
B - to battery (charge cable)
Ig - ignition (12v switched at ignition)
S - sencing wire (12v charge reference)
L - lamp (charge light)
So prob is charge light does not go completely out when the car is running.
Things to think about are the the alt provides the ground and then removes it when charging starts and all is good. ( call this situation A)
Now i could be wrong but my understanding is that in the old system the Alt provided the 12V to light up the bulb and then took it away when charging. ( call this situation B)
Now if the new alt L wire is conected ( situation A) with car not running and Ig on then we get a nice solid charge light on as it should be. But start the car and it only goes half out as the earth is taken away.
Now in testing if you have the Ig on and disconect the L wire then the light glows dimly, (same thing going on as above but not using the Alt to drop the earth, (Situation A)
But at this piont if take away the ground and you applie 12V to the wire (situation B) then the light goes completly out. This is my under standing of how the originage Alt did the job,( but could be wrong).
So if i run it this way the charge light would only ever glow dimly but would go out properly when charging was underway.
The other option (A) would see the glow well but never go right out.
So im a bit stuke in the middle of two options, but neather really work????
Out of interest I thought id combine both options and see cards came up. Hooked up a relay to provide an earth while Ig on and car not running to provide a good charge light, then as the car starts and charge circut starts to swap to a positive feed so the light goes fully out. Now this works well until to you turn the Ig on and then straght off with out starting the car. It some how keeps the Ig circut alive with about 4.5V that seems to be running back from the L wire on the Alt through the relay and in to the Ig circut and not leting the the main relay click off when you turn the key off, so result is that you cant kill the ignition. Interestingly if you put any load on the system ( e.g. indercator lights) then the power drain imedeatly flicks the main relay off.
Regarlise somthings a little more cocked up that just my spelling....
My thoughts are a bad earth on the charge light in the dash so it only glows dimly,(but all the others are working fine???), then you take away the power and its off (situation B).
Or ....that ummm.... there is a slight short to earth on the charge light in situation A so that when the Alt drops the earth the light sort of still stays on.
Now i think ive got that alright?
Thanks for reading it all, couldnt thing of an easyer way of writing it all, and it took way longer to go through it all on the car.
So if you follow it all please give me your thoughts on the problem as you obviously know a little about the subject.
Thanks
Timon
Oh and its a possablity that the grounding issue, ( if thats what is realy going on is just throught the reg in the Alt maybe cos of the way ive wired it ??
Anyway would appreseate the imput of someone who knows which way round the wiring sould be so can look for the fault.
Here is the wiring diagram. Im not the best at disifering it :( but to me it says the car is situation A just like the Alt is.
Last edited by Mr_procrastination on Thu Apr 03, 2008 11:57 am, edited 1 time in total.
Mr_procrastination
Postby gepsk8 » Wed Apr 02, 2008 8:19 pm
hey, read this
black with yellow(stripe) - Ig - ignition (12v switched at ignition)
yellow with white - L - lamp (charge light)
and i would put sensor wire to battery stud off the alt. -B - (check ur running fuse for alt )
alt reg earth the warning light when not work then feeds it to turn in off when working by feeding it (two feeds turn light off)
O272754663
gepsk8
Postby Mr_procrastination » Wed Apr 02, 2008 8:25 pm
sorry had not listed the wire colours, but yes as you have discribed it is how it is wired in situation A.
The only change i had made is to try reversing the the L output with the relay making it an on off power feed from the altenator.
And sorry i dont quite get the last bit ??
Thanks
Mr_procrastination
Postby gepsk8 » Wed Apr 02, 2008 8:34 pm
i couldn't be bothed read all that.
just wrote down colours very simalar to ke70
the reg on the 3sge alt is internal and works as i wrote down.
old one run external of the alt.
O272754663
gepsk8
Postby Mr_procrastination » Wed Apr 02, 2008 8:37 pm
Ok so is the last bit is ,
Alternator regulator earths the warning light when not work, then feeds it to turn in off when working, by feeding it (+VE????), (two feeds turn light off)
If thats what you mean this i could assume there is a fault with the Alternator, but the light is always dimly lit when the L wire is not conected at all ?
Thanks Keep it comming
Mr_procrastination
Postby gepsk8 » Wed Apr 02, 2008 8:41 pm
u taken the external reg off on side of the engine bay, 5 or 6 pin plug?
yip thats right.
O272754663
gepsk8
Postby Mr_procrastination » Wed Apr 02, 2008 8:42 pm
yes external reg is gone. It was a 6 pin
Mr_procrastination
Postby gepsk8 » Wed Apr 02, 2008 9:07 pm
sounds like ur alt $&#$%
pm 3T-Rona i think hes auto sparky up ur way.
O272754663
gepsk8
