Brake master cylinder/hydraulic theory?
Postby Burning Angel » Fri Apr 04, 2008 8:32 pm
Basicly the problem i have is this:
I have upgraded the brakes in my starlet to Gx60 on the front and lx76 in rear(or generic large T series diff drums) and now the pedal feel is quite heavy.
so it thought id put a larger master cylinder in to help(currently has the standard 3/4 one).
but then i thought wait, a smaller one would be easier to press but youd have to press it further to get the same caliper travel.
so what im asking is will a bigger master cylinder be helping the situation or making it worse?
options that i have found will fit:
KE70 = 13/16 which is smaller
r32/r33 skyline = 15/16 which is bigger
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Zak » Fri Apr 04, 2008 9:27 pm
I though the master size altered the travel of the pedal, but it's the booster that will control the effort. So maybe going to a bigger booster will help, unless you need more/less travel?
also 13/16 is bigger than 1/4 (12/16)
Zak
Re: Brake master cylinder/hydraulic theory?
Postby KinLoud » Fri Apr 04, 2008 10:30 pm
Burning Angel wrote: and now the pedal feel is quite heavy.
What do you mean by quite heavy?
1 - long pedal i.e. large movement of pedal to make brakes work?
2 - hard pedal i.e. lots of force required to make brakes work but not much movement?
I would guess that you have more caliper piston area now so you should have more hydraulic advantage and a larger pedal movement (1)?
Maybe the brake pads aren't working very well or are overheating which could lead to (2)
Ken
Ham
021 408 863
Postby Burning Angel » Sat Apr 05, 2008 7:31 am
by heavy i mean i have to press quite hard to get the car to slow down.
it stops fine but you've got to make a conscious effort to do it.
so id say #2
the pads and shoes are brand new and have been properly bedded in.
i suppose it could be that it has a small booster but there is no way im gonna fit a bigger 1 in there.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby strx7 » Sat Apr 05, 2008 8:01 am
if you have to get the pedal close tot he firewall to make it stop you need a bigger master cylinder. If the pedal is HARD and you'd like it to be softer, you need a larger BOOSTER
Postby fangsport » Sat Apr 05, 2008 8:43 am
if your mechanical and hydraulic advantage is correct, then a booster isn't needed.
are you running a bias valve?
how many outlets on he master cylinder?
fangsport
Postby Burning Angel » Sat Apr 05, 2008 6:26 pm
yes im running a bias valve. just the stock starlet one and the master has two outlets.
i havent had a chance to drive it properly as its not road legal and still has a few handling issues.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
