the manual says the best place is before the throttle body, but it can be fitted to somewhere with high airflow.
how have you guys found fitting it in the place of the factory bluetop sensor? is there enough air flow etc there, any problems having it there?
and also, with the Link G3, all the factory cold start lines/sensors can be removed right?
