more boost on a sc14 supercharger?
Postby MrDori » Tue Apr 08, 2008 9:53 pm
whats the best way to increase the factory boost a my 1ggze?
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
Postby ollieboy » Tue Apr 08, 2008 11:17 pm
Smaller Pulley on supercharger iirc. Someone should be able to elaborate more.
ollieboy
Postby Crampy » Tue Apr 08, 2008 11:44 pm
Bigger crank pulley, that way you could still have the clutch assembly on the supercharger itself.
Or, a custom smaller supercharger pulley, which would mean it'd be on constantly.
Either will do it. Or both will make even more boost 8)
Crampy
Postby barryogen » Wed Apr 09, 2008 9:28 am
you don't want to spin the SC14 more than 10000RPM though... thats about their limit before they blow them selves apart.
Oh, that and about 14lb(1bar)... any more than that they just make too much heat.
I'd be more inclined to say pull the SC off it and turbo it, it'll cost more, but it'll go faster, and with a suitably sized turbo you wouldn't notice too much change in drivability.
barryogen
2ZZ Guru in training
Postby Crampy » Wed Apr 09, 2008 5:59 pm
It's the teflon coating on the lobes the goes on them when they are spun too fast. You would definitely be looking to upgrade your intercooling if you want to pump out more boost. I'd say even upgrading the intercooler with stock boost could even give you a nice gain as well.
Crampy
Postby tsoob » Wed Apr 09, 2008 6:28 pm
barryogen wrote:you don't want to spin the SC14 more than 10000RPM though... thats about their limit before they blow them selves apart.
put a dirty big t70 on the sucker and wind the boost up!! :D :D
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby MrDori » Wed Apr 09, 2008 7:16 pm
not to worried about crazy power as ive already done that to a 1g, i like the responce the supercharger gives, but afew more psi would be sweet!
Anyone know whats involved in getting a smaller pully on it? size diff etc? supercharger clutch has been disabled anyhow
MrDori
Postby Crampy » Wed Apr 09, 2008 8:12 pm
I've heard of people adapting pulleys from alternators to suit the S/C.
A while back there was a guy from OZ that makes smaller pulley's for the SC12 ans SC14. Can't recall the website he had setup though.
Crampy
Postby pjay » Wed Apr 09, 2008 8:24 pm
put a turbo after the sc
pjay
Postby Mr Revhead » Wed Apr 09, 2008 11:17 pm
Crampy wrote:It's the teflon coating on the lobes the goes on them when they are spun too fast. You would definitely be looking to upgrade your intercooling if you want to pump out more boost. I'd say even upgrading the intercooler with stock boost could even give you a nice gain as well.
hmmmm i seem to recall some tests being done that proved it wasnt teflon....
ill see if i can dig it up
Postby barryogen » Thu Apr 10, 2008 10:46 am
Crampy wrote:I've heard of people adapting pulleys from alternators to suit the S/C.
I've read the same, the ones I read about being used were camry ones... essentially the guy went to a place like pick a part with measurements of what he had and grabbed a suitable one.
barryogen
Postby matt dunn » Fri Apr 11, 2008 12:30 am
pjay wrote:put a turbo after the sc
nah, before,
worked awesome, 30psi at 1200rpm, lol.
