Rebuilding gearboxs
Rebuilding gearboxs
Postby Adamal » Wed Apr 16, 2008 2:15 am
Got a daily driver which has a bit of a crunchy 2nd gear.
I was thinking of buying a gearbox and refitting it with new syncro's and then whacking that on.
Now, I know very little about gearboxes, so what I'm wanting to know is, is this an economically viable option? Eg, would a 3SGE manual box cost around the $50-$100 mark, and then a set of syncro's around $100-$200? Or is there a much larger amount involved?
I'm also guessing it'd be best to get a specialist involved, or would it be something that you'd be able to figure out with a bit of common sense?
Postby Maxwedge » Wed Apr 16, 2008 8:31 am
Try changing the oil if you want a quick fix, some gearbox oils are highly advanced and have additives that can eliminate syncro problems. I had a 2nd gear syncro crunch as well but I used Redline Shockproof gear oil and the problem stopped immediately. This is probably not a long term fix but its worked in my rally car and that box gets a thrashing.
Maxwedge
Postby gepsk8 » Wed Apr 16, 2008 7:13 pm
fwd gearboxs are expensive to fix. just throw another one at it, specilly if 3sfe is same box.
O272754663
gepsk8
Re: Rebuilding gearboxs
Postby matt dunn » Wed Apr 16, 2008 11:58 pm
Adamal wrote: syncro's around $100-$200? Or is there a much larger amount involved?
About $100 per gear for the syncro's,
Plus labour,
Postby Adamal » Thu Apr 17, 2008 12:00 am
So I should probably get used to double clutching then?
Postby Lloyd » Thu Apr 17, 2008 12:03 am
Get another box and chuck it in, depends how much it annoys you I guess.
Postby ChaosAD » Thu Apr 17, 2008 12:17 am
Need a few specialized tools such as a press and a bloody good set of pullers.
Cheaper and a lot less hassle to just buy another one.
ChaosAD
Postby Mr Revhead » Thu Apr 17, 2008 9:19 am
slap in a 2nd hand one
then pull apart the old one to learn/see if you think you can do it.
Postby Bumpy » Thu Apr 17, 2008 7:14 pm
Mr Revhead wrote:slap in a 2nd hand one
Great idea that one!
Bumpy
