gasket for F series live axle....
Postby RomanV » Fri Apr 18, 2008 1:29 pm
There's a gasket for the seal between the diff head and the diff housing on my F series live axle... Which is from an MA45, which you cant get parts for anymore.
Is there anywhere that I'd be able to get a gasket for this from? Do later model vehicles with F series live axle have the same shape etc?
Or would it be sweet with just gasket goo, or will I really need a proper gasket in there?
Postby thegreatestben » Fri Apr 18, 2008 1:35 pm
If it's the diff I sent you it was an RA40 that its out of.
thegreatestben
Postby RomanV » Fri Apr 18, 2008 1:48 pm
Aaaah yep! it is.
However it makes no difference either way, as neither are available anymore. :?
Postby Mr Revhead » Fri Apr 18, 2008 2:04 pm
try a 42181-22010 rrp is $5 plus gst
cheap enough even for you mr tight bum :P
thats from an early non GT r/ta40
it maynot be the same diff. but worth a go
Postby thegreatestben » Fri Apr 18, 2008 2:10 pm
The car was a GT.
thegreatestben
Postby Mr Revhead » Fri Apr 18, 2008 3:23 pm
sweet
then you want a 42181-30020 rrp $3.74+ gst
ex japan, just confirmed with toyota they are still in stock over there.
Postby thegreatestben » Fri Apr 18, 2008 3:32 pm
Just to be sure.
thegreatestben
Postby JustinSpiderholden » Fri Apr 18, 2008 3:41 pm
Pooh for the win i got some really good ge thermal glue if you want ulitmate pooh same shit they use on jet engines, heat proof to like 3000 degree's
I got a friend with s14 turbo, he has never used a single gasket on his car ever, all heald together with ge super pooh, nothing has ever failed
JustinSpiderholden
Postby Mr Revhead » Fri Apr 18, 2008 3:44 pm
yep, with those details go for the latter 8)
Postby RomanV » Fri Apr 18, 2008 4:02 pm
Whoa badass!
Cheers!
Postby thegreatestben » Fri Apr 18, 2008 4:38 pm
:D
thegreatestben
gasket
Postby Celica RA45 » Sat Apr 19, 2008 12:21 am
dave i have a few here as we keep a lot of stock and i use these for my F series as well ,do you wont me to send you 1 with the quad inlet that i will be sending next week
Celica RA45
