Auto ECU with manual gbox?
Postby AE86less » Fri Apr 18, 2008 3:27 pm
I didn't realise that there was a difference between ECUs for manual gboxes and autos when I bought this ECU off trademe:
What is the difference? And can it be made to work with my manual box?
Engine is a 3rd gen 3sge from a celica.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby barryogen » Fri Apr 18, 2008 3:58 pm
from what I've read, you just set the auto thing to park or something... someone else will be able to give you info on it.
barryogen
2ZZ Guru in training
Postby RomanV » Fri Apr 18, 2008 4:05 pm
The auto ECUs have a 5th plug in the middle, manual ones only have 4 plugs.
I unplugged my manual ECU from my gen 4 motor, and plugged in the auto ECU without anything attached to the 5th plug.... still started up and everything!
If there's a trick to making it think the car's in park or whatever, that's gonna be a loom issue not an ECU one.
Postby AE86less » Fri Apr 18, 2008 4:14 pm
Sweet, cheers guys.
So baiscally it should be fine with a few little tricks?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
