Help me keep my turbo attached
Postby quick6 » Sat Apr 19, 2008 7:44 am
So I bought another MR2 turbo and drove it home from Hamilton (to Wanganui), by the time I get back it sounds like a tractor. I poke around to find that the turbo is only held on by 1 (loose) nut out of the 4 that should be present. So I replace the 3 missing ones and get them all tight drive another say 10km then allow the car to cool overnight only to find 2 of the nuts are loose again (read not even finger tight). Repeat the above process 4-5 times. I am using the correct nuts off another engine. The studs/nuts appear to be in good condition. When everything is tight it all seals up nicely. The car has solid eurethane engine mounts which cause a fair bit more vibration so I am guessing this is quite possibly the problem. The car also has a modified cast manifold (Wastegate) which could also be contributing. Anyone got any bright ideas as to how to keep this thing held together? Does Loctite make anything capable of withstanding ex manifold type temperatures?
quick6
Postby nz_climber » Sat Apr 19, 2008 10:51 am
lockwire!
have to get nuts with lockwire holes or drill them yourself
nz_climber
Postby IH8TEC » Sat Apr 19, 2008 10:55 am
haha, someones been scanning. i was looking for that pic when i tried explaining in to matt dunn, as he had same problem,
solid engine mounts is not the cause, well shouldn't be, i haven't had any problems, barry hasn't, few others i know haven't either.
but yeah lockwire will sort the problem
Postby pc » Sat Apr 19, 2008 11:12 am
Is the exhaust braced/bolted to the block after the turbo?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby nz_climber » Sat Apr 19, 2008 1:30 pm
Brendon. I just found that on the net, good ol google images.. :)
nz_climber
Postby Mike- » Sat Apr 19, 2008 3:15 pm
spring washers?
Mike-
Postby Dell'Orto » Sat Apr 19, 2008 4:09 pm
Ordinary spring washers might detension with the heat cycling though.
Postby flygt4 » Sat Apr 19, 2008 4:14 pm
stiffer/solid engine mounts do create a lot more vibration though, i would think it to be a contributing factor.
flygt4
Postby IH8TEC » Sat Apr 19, 2008 5:35 pm
if that were the case, why have i myself and alot of others never had a problem, and yeah i find spring washers are crap on the manifold. i use flared nuts like most factory's use for exhaust systems.
next best option, lockwire them, pm matt dunn and see what solution he used.
Postby atmosports » Sat Apr 19, 2008 6:35 pm
I've always just used aircraft grade metal lock nuts, obviously the ones with the metal locking insert rather than nylon like in nylock nuts which melts, never ever had one come undone on heaps of turbo cars. I always crank them up cold, then give the car a good thrash & let it cool down again & doubl check them.
Else you could use lockwire, a split pin/R-clip, a lock washer or two nuts is space allows & you want to drill some holes.
Else you could also get some high-temp threadlock like I've used on furnace fasteners before or run a dab of high temp silicone on the threads etc so that if it does come loose if won't rattle off completely.
atmosports
Postby Crucible » Sat Apr 19, 2008 6:38 pm
you can use the flange gasket as a template, and make up a couple of locking tabs out of something like .8mm panel steel.
basically just drill a couple of holes through each plate, they sit between the nut and flange, then you just tap the sides up so they sit against the nut flank.
and yep, always double check the bolts after it has been run and cooled down. Youll find they will probley come up a fair bit.
Crucible
Real Life Mechanic
Postby RedMist » Sat Apr 19, 2008 9:11 pm
Nord Locks. I use them on my offroad race car and have never had one fail. Never had a turbo race car before, but we have installed them on the new twin turbo offroader as I'm confident they wont release.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby method » Sat Apr 19, 2008 9:18 pm
Use a high temp locking compound?
PICS UPDATED DAILY
method
Postby ee904age » Sun Apr 20, 2008 2:42 pm
RedMist wrote:Nord Locks. I use them on my offroad race car and have never had one fail. Never had a turbo race car before, but we have installed them on the new twin turbo offroader as I'm confident they wont release.
Agreed, we have them at work (McDonald Equipment) give them a go.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby quick6 » Sun Apr 20, 2008 6:33 pm
Heaps of ideas there, cheers guys. Those Nord Locks look like a simple solution so I will give that a go first. Lost another nut today, tightened before driving for 10 ish km and was gone when I got home. On the up side the other three were still tight.........
quick6
Postby matt dunn » Sun Apr 20, 2008 11:21 pm
Where did you source them? NZ or overseas ?
Postby RedMist » Mon Apr 21, 2008 8:07 am
All the fastener places in CHCH stock them. Blacks, Hylton Parker etc. They really are a fantastic product. One hell of a lot easier and quicker than wire.
RedMist
